Loss of Display Properties 'center' and 'stretch'.
Xenos
Can anyone tell me why my desktop backgrounds only come up in tile format? Why can I no longer select stretch or center if I wish? Why does my Display Properties window only give me three tabs i.e themes, appearance, and settings? Where did the other two tabs disappear to? Am running xp pro.
This can be caused by malware (virus/spyware) or may simply be caused by an unregistered dll library file.
To re-register the files, click on the Start button, click Run, then type cmd and click OK or press Enter. In the command prompt window, type regsrv32 themeui and press Enter, then type regsrv32 /i shell32 and press enter. Reboot the computer for the changes to take effect.
If this does not fix the problem, you probably have a malware infection that needs to be removed - do a full system scan with good virus and spyware removal tools. If you don't already have something installed, I prefer Avira AntiVir and Malwarebytes (both are free and work very well).
Thank you Fardringle, you're a genius. It was a virus. Malwarebytes found four of them, two of them refering to my background display. These were the culprits. I had malwarebytes delete them and now I am back to a decent desktop background. Many thanks once again.
