That's nice
I'm a bit disturbed by the fact that the memory isn't officially compatible. Despite it apparently working fine, I'm going to stop recommending G.Skill value for overclockable sandy bridge setups and instead refer to RAM listed as compatible by the mobo manufacturer.
Given what happened, you should indeed overclock a bit more carefully. Try googling other people's results with 2500K overclocks - in particular, what core voltage proved stable for 4.5GHz or so.
Sorry I hadn't noticed this before but the G.Skill Value memory does not seem to be compatible with the Z68 chipset (or any LGA1155 chipset), and it's also not listed on the Asrock Z68 Pro3 list of supported memory modules. But since it worked for you before you overclocked, and it has also worked fine for newegg reviewers with sandy bridge setups, I don't know if this makes sense... Still, it would be best to return the RAM to newegg, get RAM that is listed as compatible (http://www.asrock.com/mb/memory.asp?Model=Z68 Pro3) and see if that solves your issue. If that still doesn't work, it sounds like your mobo got damaged somehow (but I'm not that technical, can't say for sure)
Are you also sure you were running the memory at 1.5V and 1333mhz?
I'm not sure what all this means, but the computer is running great. I don't think your recommendation was off even though it is not "officially" supported.
I am trying overclocking again. This time I did more research lol.
I'm running Prime95 and CPU-Z to test numbers and I managed to get 45x at 1.256v. I have the CPU Voltage Offset on 0.045v.
Where did you get the idea that it is not compatible? The list of memory on ASRock's web site is just what they have tested. Obviously, they cannot test every DDR3 kit under the sun.
Isn't it obvious where I got that idea? "Memory Support List" kind of implies that anything else is not supported, officially.
A G.Skill has also said in a newegg review comment that they recommend the Ripjaws for LGA1155 systems.
Because they want you to spend more money on the ripjaws they are the same modules![]()
In order to honestly say that they "support" a given memory kit, ASRock has to actually test it, which they don't have unlimited resources to do. Any standard DDR3 is "compatible" though.
I suppose you're right. It does need to be 1.5V though... Or is this another example of "compatible" vs "supported"?
