Looking for the best shower head - high flow - firehose-like
Discussion in 'Off Topic' started by Nvidiaguy07, Mar 17, 2012.
Thread Status:
Not open for further replies.
  1. GregGreen
    GregGreen Golden Member
    Dec 5, 2000
    1,672
    You forgot the NPT to hose thread adapter :)
  2. tboo
    tboo Diamond Member
    Jun 25, 2000
    7,627
    Get any regular shower head & drill it out.
  3. artvscommerce
    artvscommerce Golden Member
    Jul 27, 2010
    1,121
    this thread reminds me of a great seinfeld episode. black market shower heads ftw.
  4. rivan
    rivan Diamond Member
    Jul 8, 2003
    9,678
    What did you end up with?
    I'm looking for a new one myself.
  5. Midwayman
    Midwayman Diamond Member
    Jan 28, 2000
    4,682
    24
    I removed the restrictor on the one that I bought at home depot. Turned a horrible dribble into a raging torrent. I actually added a valve before the shower head so I can fine tune the water pressure.
  6. edro
    edro Lifer
    Apr 5, 2002
    24,338
    66
    Thanks for this thread!
    I knew all new shower heads and faucets were low flow compared to the old days... but I didn't know they were easily modified.
    We just finished our bathroom renovation last week. We have a Moen ~10" shower head and were disappointed with the flow rate. I took it off last night, removed the rubber washer, then grabbed the green plastic regulator with pliers and it popped right out.
    I was worried it was designed to redirect flow to all of the nozzles equally... but that wasn't the case.
    It works great now! Easily twice the volume/pressure, probably more.
    Eat that you water hugging hippies!
  7. CraigRT
    CraigRT Lifer
    Jun 16, 2000
    31,442
    Same... A classic indeed
  8. Vdubchaos
    Vdubchaos Lifer
    Nov 11, 2009
    10,418
    Costco has shower heads that most hotels use (speakman or something) for like 20 bucks. You can adjust them to spray like hose.....
    DO NOT buy any of those "efficiency" BS showerheads. All they do is restrict the water pressure and make your pipes shake like crazy....
  9. Rakehellion
    Rakehellion Lifer
    Jan 15, 2013
    12,135
    10
    Your wife gave me the best shower head this morning.
  10. edro
    edro Lifer
    Apr 5, 2002
    24,338
    66
    They are ALL efficiency shower heads now.
    It is illegal to manufacture anything over 2.5gpm.
  11. jupiter57
    jupiter57 Diamond Member
    Nov 18, 2001
    4,601
    Before you got on the "Short Bus" to go to your "Special" class?
    Or are you like most ATOTers, "Home Schooled"?
    Are you even old enough to get an erection?
  12. Mixolydian
    Mixolydian Lifer
    Nov 7, 2011
    14,522
    65
  13. Murloc
    Murloc Diamond Member
    Jun 24, 2008
    5,321
    51
    I never had a problem with new showerheads being restricted, I don't think they are here.
    The problem is that some hotels have low water pressure and there's nothing you can do about it. I hate that.
  14. Midwayman
    Jan 28, 2000
    4,682
    24
    I know right? Nothing worse than a weak shower. Can't even keep all of you warm with its low flow and takes forever to get soap off. I'm also on a mission to fix low flow toilets.
  15. jupiter57
    Nov 18, 2001
    4,601
    If you have low water pressure, no shower head in the world will help.
    I have an older generic "Shower Massage" type head I bought at Big Lots many years ago. I removed the restricter for better flow, and it worked very good when I had good pressure.
    After we sold our house 3 years ago, we moved temporarily to a community with very dismal water pressure. (Think when you flush a toilet, your shower STOPS!)
    Lowes had a Pump you connect to your water line to increase your pressure, it cost me $300 but was well worth it, IMO.
  16. waterwizard
    waterwizard Junior Member
    Jan 11, 2005
    Just removed the flow restrictor from the second cheapest head they sell at Home Depot. Wow! The restrictor has TINY holes. I bought a modified one off of ebay for another place a few years ago and meh. But this is perfect! I do have decent flow here. Just about the best shower I've ever had. Problem now is hot water will run out fast. Try this before you go buying something expensive.
    #66 waterwizard, Jul 7, 2013
  17. Howard
    Howard Lifer
    Oct 14, 1999
    47,985
    7
    No. The orifice will experience higher velocity, but the overall flow rate and velocity at the showerhead nozzles will decrease.
  18. Broheim
    Broheim Diamond Member
    Feb 17, 2011
    4,592
    holy necro/lurker combination batman :eek:
    MINE!!!
  19. edro
    edro Lifer
    Apr 5, 2002
    24,338
    66
    I'll give an update on my experience.
    We still love the extra flow/pressure, but it drains the water heater with 1 regular shower.
    If we want to take back to back showers, we have to wait 10min or so.
    Still worth it.
  20. Donald567
    Donald567 Junior Member
    Aug 8, 2015
    Wow, I sure wish I had one like Kramer in that episode of Seinfeld. Does anyone have a high pressure badass shower head to recommend that is like the Commando 450?
  21. tortillasoup
    tortillasoup Golden Member
    Jan 12, 2011
    1,967
    A decent Toto toilet needs no "fixing". Best damn flushing toilet, much better than the crappy 5 gallon or 3.5 gallon toilets it replaced.
  22. shortylickens
    shortylickens No Lifer
    Jul 15, 2003
    67,390
    3,406
    Read the dates, noob.
  23. IronWing
    IronWing Lifer
    48,418
    3,854
    Where to buy it was linked above, three and a half years ago.
  24. Leyawiin
    Leyawiin Diamond Member
    Nov 11, 2008
    3,161
    41
  25. tortillasoup
    Jan 12, 2011
    1,967
    Toto has been making excellent toilets and is part of the reason why they even had the low flow standard put in in 1994. American standard can't make a toilet worth a shit even 20 years later.
Thread Status:
