- Aug 31, 2001
- 21,205
- 165
- 106
I am replacing my single aging furnace with 2 new units - one 95% furnace in basement for 1st floor and one 80% in attic for 2nd floor. I am keeping my current Trane condenser for 1st floor, and getting a new AC unit for 2nd floor.
I have two quotes from the same contractor for two different brands
1. Coleman units for $14K
Coleman TM9V 96%, 2 stage burner, variable speed motor, 100K BTU
Coleman TM8V/TMLV 80%, 2 stage burner, variable speed motor, 100K BTU
Coleman TCJF 16 SEER 4 ton R-410A condenser
2 Honeywell wifi 2 stage thermostats
1 yr warranty on labor and parts by contractor, 1yr factory warranty on parts, 5 yr factory warranty on furnace, 10 yr factory warranty on condenser
2. Trane units for $19K
TUH2C100A9V5VB 95% 2 stage variable speed furnace
TUD2C100A9V5VB 80% 2 stage variable speed furnace
Trane condenser 4 Ton 18 Seer R-410A for second floor
I know nothing about Coleman. I know Trane is considered a good brand. But is it worth it to spend the extra $5K on the Trane units?
Thank you in advance.
