- Sep 13, 2001
- 53,531
- 6,356
- 126
I am currently trying to basically use 2 separate PSU's to make one of my arcade games work.
One is built into the cabinet and is a standard arcade PSU and but then I am using another ATX PSU to power one very specific game.
The specific game is a beast and is in it's own metal cage with 4 large PCB's that connect to a smaller motherboard, and then there are 2 other smaller boards that are all hooked together. There is also a 12v fan hooked up to it.
I plan on using the ATX PSU to power the actual game itself. I had to wire up an adapter that went from my arcade cabinet JAMMA adapter to the game itself. However, due to the long power wire run, there is a drop of .5v when it hits the actual game and that causes it to not get enough power. So that is why I plan on using an ATX PSU to power it.
There will be no power at all coming from the JAMMA adapter to the game. All power going to the actual game will be via the ATX PSU.
But the insides of the cabinet that power the switcher that allows me to select this game, as well as turn on the PSU with a relay I have hooked up, are coming from the PSU inside the arcade cabinet.
My question is, do I have to connect the ground wires from the ATX PSU to the ground on the arcade cabinet PSU? I wasn't sure if this was necessary or not because I'm a noob with this stuff and because the game itself is being completely powered from the ATX PSU, however things like the monitor and coin box are being powered by the arcade PSU.
So anyone know if I need to just run a ground from the ATX PSU to the ground in the cabinet PSU? Would there be any downside if I just did it anyways?
I can go into a bit more detail if need be so feel free to ask any questions.
