R RedBeard Diamond Member Sep 29, 2000 3,403 0 76 Dec 8, 2005 #1 Trying to find a small gamepad that is USB. Going to use it for old console emulation. Doesn't need analog stick. I saw the gravis "stinger" but it is serial. Anybody have any recommendations?
R RedBeard Diamond Member Sep 29, 2000 3,403 0 76 Dec 8, 2005 #3 all I can find is the speedpad, am I missing something?
C crizzar Member Jul 17, 2004 147 0 0 Dec 9, 2005 #4 No, technically it's the Nostromo Speedpad n52 Belkin site Awesome accessory and works great for all games. All the keys can be programmed with regular keystrokes or set up to run macros.
R RedBeard Diamond Member Sep 29, 2000 3,403 0 76 Dec 9, 2005 #5 Doesn't look like it would work well with emulation or am I missing something?
BlueWeasel Lifer Jun 2, 2000 15,944 475 126 Dec 9, 2005 #6 Why was the Speedpad mentioned? He asked for a gamepad.
R RedBeard Diamond Member Sep 29, 2000 3,403 0 76 Dec 9, 2005 #7 Originally posted by: BlueWeasel Why was the Speedpad mentioned? He asked for a gamepad. Click to expand... I thought I was going crazy
H HDTVMan Banned Apr 28, 2005 1,534 0 0 Dec 9, 2005 #8 Try this. http://www.geeks.com/details.asp?invtid=PCJOYPAD-BLU-N&cpc=SCH&srm=0 They have better ones as well. You say gamepad I say speedpad. You say Tomato and I say Tamaters.
H HDTVMan Banned Apr 28, 2005 1,534 0 0 Dec 9, 2005 #9 Another option if you have a controller already you like is get a joybox.
R RedBeard Diamond Member Sep 29, 2000 3,403 0 76 Dec 10, 2005 #10 wow, that is cheap! Hmm.. Looking at this or Gravis Gamepad Pro.... hmmmm... Another rant: Seems like ALL the controllers are shaped like the PSX ones. What about simplier SNES type ones?
