- Jul 30, 2007
- 5
- 0
- 0
I am wanting to build a system in a smaller case size to fit on top of my desk. The issue I have is that the desk is against the wall, and also has side panels at the end where the box would be sitting. I am concerned about airflow "around" the case, and the restriction of it being so close to a closed surface.
I was thinking of maybe an htpc style case, as it would be stylish in the setting, or should I consider a shuttle style case? I am worried about the heat being exhausted in an efficient manner, and don't want anything really restricting the airflow.
Do you guys have any ideas on a certain case that might work on the desk area and not possibly have heat build-up?
I am thinking about a setup including:
Core i7
VelociRaptor
xp pro
2gb ram
dvd burner
gtx 260 card
THANKS!
Core i7
VelociRaptor
xp pro
2gb ram
dvd burner
gtx 260 card
THANKS!
