Looking for Quiet PSU (Modular, Possible CF)
tential
Looking for a new PSU for my build currently it's
4770k
7950 Sapphire
8 GB Ram G-Skill
Z87-A Asus Mobo
Define R4 Case
SSD (not picked)
4-8 HDDs (final currently 3-4)
Just looking for a quiet PSU/efficient PSU that won't generate much heat. I don't know how much heat HDDs generate and I'll be ending up with quite a number until I can get a separate server PC. For now though, all of them end up in my gaming rig which sucks.
850W Hec 80+ Silver Certified Power Supply (HEC-850TS)
This any good?
It's on sale for $40.
If not then:
CORSAIR CX600M 600W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply - 70
http://www.newegg.com/Product/Produc...82E16817139048
SILVERSTONE ST60F-P 600W ATX 12V v2.3 / EPS 12V 80 PLUS BRONZE Certified Modular Active PFC Power Supply - 70
http://www.newegg.com/Product/Produc...82E16817256064
CORSAIR CX750M 750W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply - 80
http://www.newegg.com/Product/Produc...82E16817139051
EVGA SuperNOVA NEX750B BRONZE 120-PB-0750-KR 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Power Supply - 75
http://www.newegg.com/Product/Produc...82E16817438007
COOLER MASTER Silent Pro M2 RS620-SPM2E3-US 620W ATX12V V2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Full Modular Active PFC Power Supply - 65
http://www.newegg.com/Product/Produc...82E16817171068
COOLER MASTER Silent Pro M2 RS720-SPM2D3-US 720W ATX12V V2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Full Modular Active PFC Power Supply - 65
http://www.newegg.com/Product/Produc...82E16817171067
These are my choices any help?
The CoolMaster in particular for 65 is a great deal. I'd like that haha.
What do you mean? Some of the units he listed are $75-80, and this one is $80 AR. In the end, you spend the same. It's really an insanely good deal for a modular 80+ gold unit from a decent manufacturer with 7 year warranty. I might even recommend that without the rebate, considering the OP's requirements (quiet, modular, possible CF).
What is your price range??
Can't go wrong with Corsair its been the best and quietest psu i've ever owned.
I ordered the CoolMaster. Was that a good choice? I hadn't had any replies and I needed to pick something.
