Looking for PCI-E video card with dual DVI and passive cooling
BG4533
1,892
I am building a new PC and need to buy a PCI-E graphics card. I run dual LCDs and want dual DVI. Silence is very important so I want passive cooling. Image quality and stability are important, gaming is not. I would like to spend around $100, but up to $200 isn't an issue. Does anyone have any suggestions?
I have no problem putting an aftermarket passive cooler on a card, so if you have a good combo solution please let me know.
Thanks!
CKXP
926
Originally posted by: BG4533
Originally posted by: emilyek
I see your BAM and raise it by 128bits ;):
http://www.newegg.com/Product/Product.asp?Item=N82E16814150162
That looks like it would fit my needs well, but Newegg lists it as 1 DVI and 1 DSUB yet the picture shows dual DVI. I cant find this exact card on XFXs website. Any ideas what this card actually has?
it's dual DVI, i bought the same exact card from newegg...great little budget card btw
BG4533
1,892
it's dual DVI, i bought the exact same card from newegg...great little budget card btw
Awesome, thanks!
acegazda
2,689
Check this out Can't match the 256bit bet however, I rasie you 3x the performance. Smoked!;) It's more expensive than the previous suggestions, but the performance gain over the others is well worth it. $160 shipped!
emilyek
511
After looking at it some more, I'm not 100% sure it's actually 256-bit :eek:; although I'd bet my house that it is dual-dvi since the pictures show it and a reviewer mentions that it comes with a dvi to analog adapter, also like the pictures show.
Edit: oops didn't see earlier posts
BG4533
1,892
That was my initial choice, but if I am not gaming will this card give me anything that the cheaper 7300GT won't? It seems my $70 would be better put towards a CPU or memory.
acegazda
2,689
hmmm... the image quality in graphic rendering apps will be better but you won't see much difference elsewhere. The 7300gt is a guy buy for your purposes. If you ever want to game though, that 7600gt is supposed to bench higher than active cooling 7600gt's. It's a lot better cooling ability than a regular passive heatsink due to its heatipie design.
