Since the crossposted thread was locked, I'll copy/paste the info here:
I used to do system builds in that case, LOL. I got them from a distributor in Walnut, CA. I know that Athena Computer Power has them. The older ones had dual 80mm exhaust fans but the newer ones have a single 120mm. It is available in beige and black. Newegg used to stock them, but no longer does. I don't know who does, or if it's even being made.
