Originally posted by: aigomorla
Originally posted by: Zepper
U2-UFO, big and fugly yes! Best, not likely. Compares like a Grandma Moses painting to a DaVinci to something like the Silverstone SST-TJ07 or the Tai Chi. Even the build quality of the CM Wavemaster or Praetorian shades the UFO.
.bh.
FYI, the build quality of the Wavemaster and Praetorian is 2nd to none.
Cou*Lian Li V1000B*gh second to none eh? Ummm yeah i know its about 70-80 dollars more, but you did say second to NONE.
Sure the V1000 is better case but I doubt it's built any better.
what is that supposed to mean, the v1000 is a better case, but the build is worse than a wavemaster? lol. okay
i dunno how people can compare lian li cases to coolermasters or TT's or Antecs. the quality just doesn't compare. Lian li doesn't have the technological advances of TT? well sorry if LL cases dont have colorful clips for their PCI cards which are loose and/or flimsyif it gets knocked around. sorry if LL cases doesn't use slide rails for their 5.25 or 3.5 bays... the money from the cheap plastic is spent in quality scratch proof panels around.
all in all, case's are subjective... some people don't feel a need to get a nice good quality case but then again, some people also don't feel a need to get good quality psu's either
Show me a LL that can come close to the TAI CHI in features and space, and i'll shut up about the tai chi.
Show me a LL That can topple the Silverstone TJ-07 and i'll shut up on worshiping that case, and might even stop me from getting one.
Prove to me that TT Armor and kandolf are made more out of plastic then aluminum/steel, and i will believe your blanket statements that TT's are cheap and worthless.
Most importantly, SHOW ME A LL THAT HAS 11 FRONT BAYS + a 3 Hard drive cage in the REAR, all for sub 150, and i'll stop trying to prove to you that LL isnt the best choice for people on a budget.
If you cant prove 2 out of the 4 i listed then you need to stop flaming TT cases, because right now you dont have much credibility.
ALSO ive had the V1000, and the PC-7B. And you know what? They dont compare ****** to my armor. If i had to pick all over again, id get the ARMOR, if i had more of a budget the TJ-07. If i wanted to act stupid and look just bling bling, then I MIGHT concider a V2000 or even another V1000B. But these two cases will fall greatly in comparison to a TJ-07.
Give me a even higher budget and i'd build myself another computer out of the TAI-CHI. Ask anyone who has a TAI-CHI, The only bad on that case is the emense size and weight, but other then that, there isnt a case that can come close to its quality and features.
