CAlbertson
I'm trying to decide on a CPU, then I will pick a motherboard. The only thing I care about (in order of importance) is:
#1 power consumption.
#2 It has "just enough" performance for my application
#3 Cost, lower is always better
I'm building a NAS that will run freeBSD and ZFS. I need at least 8GB of ram and the Intel D525 Atom CPU is almost powerful enough except it has a limit of 4GB RAM. I'm looking for a step up from the D525 but power use is really a big deal as I'm running more than one of these 24x7
BTW I really like the new WD "Red" disk drives. Will use them in ZFS' RAID-Z2. This is the best (in terms of data integrity) files system on Earth but it does requires tons and tons of RAM and I will likely need to go with 16GB even for a small 8 drive array.
As for performance needs.
1) Don't care about graphics, the system will run headless with no monitor or keyboard
2) The main bottle neck is stuffing bits down a 1000BaseT Ethernet port at the full wire speed. Once that can be done there is no point in gong faster. So the NAS server is like watching a DVD video where there is no point in playing the movie at double speed, The 1.8GHz Atom is about 70% of required performance.
Whatever I do buy needs to go into a motherboard that can (maybe with a add-in card) drive eight SATA disks. What about mobile CPUs? Are there MBs that can use a low power mobile CPU? The availability of a suitable mother board may drive the selection of a CPU.
I'm looking for pointers and terms I can Google. I do have a good background in computing and a degree in computer science but my background in NOT with PCs or IT. It is all in embedded micro controllers, radar signal processing, digital camera design and so on.
Thanks,
Chris
Thanks,
Chris
