- Jul 12, 2011
- 12
- 0
- 0
Hi everyone,
Looking to upgrade my '08 desktop (C2D).
85% video editing, capturing, encoding and possibly transcoding/streaming. Music editing and input. 10% light gaming (World of Warcraft doesn't need to be on ultra) 5% virtualization software (virtualbox).
$500-600. I already have hard drive, optical drive and a HD6850 video card.
Canada, but don't worry too much about this. I'll scour the internet for prices. Just pretend I get things at US prices but without specials.
I will need intel's VT-d functionality, so I can't use the "k" unlocked cpus from what I understand. I also have a HD6850 card I want to reuse so I guess I'm ATI for now. And I think I need gigabyte motherboard specifically for the virtualization.
I have an Asus DirectCU HD6850 video card. I think it's dual slot but I don't quite remember. I have hard drives and optical drives, monitors and keyboard mouse etc. I have Roxio usb 2.0 video capture device that I'd like to use though. Right now it's chugging on screen a lot during capture (but the video is fine).
I do not plan on overclocking anything.
1920x1200 is what my screen is showing right now, but I shan't mind if it goes higher.
Before June 15th would be amazing.
I have a windows 7 pro so I should be okay.
And thank you for that!
Questions:
1. Can I use H77/H87 motherboards if I have a dual slot video card?
2. Does video editing software take advantage of my video card?
3. Even within the H77/H87 motherboards, there are so many different cersions from the same manufacturer, and it's not just the form factor. How do I know which one is better?
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
3. What country YOU will be buying YOUR parts from.
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from.
We can't be expected to scour the internet on your behalf, chasing down deals in your specific country... Again, help us, help YOU.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
7. IF YOU plan on overclocking or run the system at default speeds.
8. What resolution, not monitor size, will you be using?
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
At the end of the day it's your money. There's only so much we can do.![]()
Questions:
