For months I have been looking for a PDA, finally got one in Dec 2001. Most people in the PDA world would
tell you to get the Sony Clie model. I got myself a Sony Clie 320 (Uses Palm O/S), because it has 8MB RAM and expandable with Sony memory stick (Up to 128MB). 128MB on a PDA is A LOT. PDAs files do not take as much space as Windows program, hence the Sony PDAs would give you more expandability. There are more people using Palm OS than Windows CE, altough Windows CE is slowly gaining porpularity. Windows CE units tend to me a lot more expensive.
If you are more into software for your PDA, I would suggest Palm O/S. There's also a lot more software
pirates in the Palm community (If that makes a difference to you) 😉.
