Originally posted by: Chronoshock
The Sunbeam Rheobus Extreme is the only controller which can provide close to enough power.
Almost half of the control range of each knob is useless as the minimum output voltage is 0V as reported in this review for the updated version.
http://www.techpowerup.com/rev...Sunbeam/RheobusExtreme
And you can see the specs on the manufacturer's web site.
Part Number: RHK-EX-SV, RHK-EX-BA
DC Input: +12 V (Standard 4 -Pin Connector)
DC Output:
0V - 12 V DC
LED Lamps: 12 * Blue LED 5.0 V
There is no voltage regulation. As you can see in this picture.
http://www.techpowerup.com/rev...eme/images/sbrbe15.jpg
So, the output voltage is extremely dependent on the load you put on it.
In other words, if you set the output voltage to 9V for a 40mA fan and then switch the fan with a 400mA fan at the same setting on the knob, the voltage could drop to something like 7.5V.
If you set the knob to give you a voltage of about 6V on a 40mA fan and then swap the fan with a 400mA fan, at the same setting, the voltage may drop to something like 4V and not start at all.
I did some measurements on a different model, but similar design from the same manufacturer here.
http://forums.anandtech.com/me..._key=y&keyword1=thumbs
