Question Looking for fans and fan controller for use with Corsair 900D
FordFreak2013
I am working on transitioning my main PC from a Lian-Li PC-75 over to a Corsair 900D. I have a Bitspower Leviathan XF 420. I have 3 of these on the way. https://www.amazon.com/gp/product/B00KFCQY94/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
The radiator will be mounted up top with the fans mounted on the bottom push the air up through the rad with the air exiting the top of the case. The case came with 3 Corsair a1225l12s-2 mounted in the front and one Corsair a1425l12s-2 in the back.
I want to make the bottom a separate compartment kind of like this guy did.
I plan on mounting all of my HDs in the bottom. Here's what I'm thinking for air flow and fan control.
- Top 2 front fans - blow in to the upper area and controlled by one knob.
- Bottom front fan blow into the lower area and controlled by one knob.
- Three rad fan blow through rad and out the case top controlled by one knob.
- Rear fan blow in and controlled by one knob.
The CPU and GPU will be on a single loop.
What fans would you recommend to replace the OEM fans? I don't want anything with lighting.
What about a fan controller? Want a black one with at least 4 channels. Prefer more in case I decide to make some changes later on.
