Question Looking for Dual Monitor Arms for Large Monitors
I was going to suggest WALI but they doing some weird changes. The original one I bought supported 2 - 24" monitors, and it has a dual vice grip to mount on back of desk.
Just got a 27" pole and new 27" Asus monitor and the Mount is much smaller. It's got a single vice grip, the pole height is smaller and the arms are shorter by an inch !! I ended up just keeping the original mount and shifted it over 2" to the left and everything is perfect supporting 27" and 24"
If you look at the Dual / Triple Arm for Jestik, it's listing for $140. That is a much bigger height and you can just remove the top part. It says up to 2 - 32" , but there good chance you can do it since mine says it supports 2x 24" and I'm using 1x 24" + 1x 27"
