i am not sure what they are called or where to get them, but i have seen them before. i am looking for an ATX power extension cable, but with a twist--it makes a 90* turn so that the cables go out at a right angle. the reason why i need it is because i am putting an Epia 800 in an IBM Netvista case and the cables from the power supply are directly under the CDRW drive. if i can get the wires to go out at a right angle, the drive would fit in place--as it is now, the drive cannot sit with the cables shooting out. i figure if i can't find this thing, i can take apart the ATX connector and hand-wire the 20 wires individually, but i REALLY don't want to do that.
