ShortCappy
I was looking to find an alternate solution to share my printer (HP DeskJet 6122) through a network router (Linksys WRT54G) without having to pay for a print server. My printer doesn't have an RJ-45 port in the back of it, only a USB B female and LPT ports. It also doesn't have it's own MAC address.
I browsed and ordered two adapters: Zonet ZUN2210 (USB-ethernet converter) and a USB gender changer A female/B male. I already had a spare ethernet cable ready to connect between the router and the USB-ethernet adapter. The way I wanted to set it up is: router -> ethernet cable -> ZUN2210 -> USB gender changer -> printer.
Hoping that this cheaper setup would work after receiving both of the adapters, hooked them up, and turned on the printer, the ethernet LED on the connected port to the printer and the lights on the Zonet ZUN2210 wasn't lit at all. I installed the ZUN2210 drivers on my PC, ran the diagnostics, and it didn't recognize my setup. I uninstalled and reinstalled the printer drivers so that it'll recognize the printer connected by ethernet and tried giving it the cloned external MAC address, but neither worked. My setup has failed.
Is there an actual alternate way to use my printer on a network without having to buy a print server? Or is a print server the only way to share a printer between PCs without dedicating a printer to a PC?
