UPDATE:
Ended up getting Manfrotto 055 Classic Legs and the SV BH8 Ballhead. Total was around $140
I'm considering getting the following:
Smith Victor BH8 head-$60, weighs 725g, has 40 lb load rating (has a pan lock, which the Giottos lacks):
http://www.adorama.com/SVBH8.html
OR
Giottos M7001 with 621 QR plate: $65, weighs 595g, has 13 lb load rating
http://www.bhphotovideo.com/c/produ..._621_M7001_Ballhead_with_Sliding.html#reviews
And one of the following sets of legs:
Manfrotto 190XDB-11 lb load rating, 3.5 lbs, $98
http://www.adorama.com/BG190XDB.html?searchinfo=Manfrotto+190XDB
OR
Slik 700 DX: 15 lb load rating, 5.8 lbs, $100
http://www.bhphotovideo.com/c/product/557127-REG/Slik_615_317_700DX_Pro_Tripod_Legs.html
OR
Cullmann Magnesit 525: 13.2 lb load rating, 4 lbs, $90
http://www.adorama.com/CUM525.html
Which combination would be better? I know the heads aren't the best, but I am not planning to use heavy lenses with them and I feel that I can always upgrade down the road if I decide to get a long telephoto.
I'm currently looking for a tripod to support my gripped EOS 40D and lens. Normally I do not use any lens heavier than a Tamron 17-50, but I may get a 70-200 f/4L down the road. I don't plan to use a really heavy lens like a 70-200 f/2.8 or 100-400 with the tripod, so I don't think I need any thing super heavy duty.
That said, I'm looking to spend between $100-150 (less if suitable options exist).
Some options I'm considering (all are under $150):
1) Manfrotto 190XDB legs ($98) with a ~$50 ballhead (do any decent ballheads exist for under $50?)
http://www.amazon.com/Manfrotto-190X.../dp/B000N81BXO
2) Slik 330 DX ($100) with the included 3-way pan head (might get a ballhead later down the road).
http://www.amazon.com/SLIK-PRO-330-D.../dp/B00009R6R9
3) Dolica Proline CX620B104 Carbon Fiber tripod w/ballhead ($130, might upgrade the ballhead down the road, I've heard reports of people putting 500mm lenses on the Dolica's CF legs after upgrading to a better ballhead like a Cullmann 35nm).
http://www.amazon.com/Dolica-CX620B1.../dp/B001MYL1BA
4) Cullmann Magnesit 525 Aluminum legs ($90) with a decent ballhead under $60 (suggestions?)
5) Flashpoint TP-102 aluminum tripod with ballhead ($90)
http://www.adorama.com/FPTP102.html?...shpoint+tripod
6) Flashpoint F-1128 Carbon Fiber legs with a cheap ballhead (this would go over 150, but if there's a ballhead around $50 that works well with this, I'm all ears).
http://www.adorama.com/FPTPF1128.html?searchinfo=f-1128
Or is there something better than these 5 that I should consider in my price range?? Weight is not a huge concern, but I would like for the tripod/head combo to not be over 6 or 7 pounds at most.
My biggest issue right now is finding a suitable ballhead for around $50. Does a decent ballhead (preferably with pan lock and adjustable friction) even exist in this price range? If not, how much would I have to pay to get a decent ballhead for my setup? It doesn't have to be super heavy duty since I won't be using it with a very heavy lens.
Thanks in advance
OR
OR
OR
Thanks in advance
