Looking for a specific Power Color PCS+ 390 Bios
atticus14
174
I really like my card but it has one flaw...its throttle temp is set too aggressively @ 65c
Took me awhile to figure this out since it never dawned on me that they would set a temp so low, but anyways this made me research as best as i could and I've been flashing other cards bios, but they just simply didn't work at all.
according to this review my card should have shipped with a 75c throttle instead
http://www.fudzilla.com/component/k2/38040-powercolor-r9-390-pcs-8gb-reviewed?showall=1
Thermals and Noise
Thanks to the custom cooler design, the PCS+ does not have a problem keeping its GPU clock high during extended intensive GPU load scenarios. The temperature goes up to 74 degrees Celsius, which is relatively low for such a big GPU.
PowerColor initially set the BIOS to keep the GPU temperature under 65 degrees, but during our review we received a new BIOS that will ship on retail cards. The new bios allows for 74 degrees, trading temperature for lower noise.
I cant find it (the bios) on techpowerup
this seems to be it, but I tried it and the same thing happened, plus for some reason my Keyboard didn't work.
https://www.computerbase.de/downloads/systemtools/grafikkarten/powercolor-r9-390-pcs-plus-bios/
anyone have any ideas? Afterburner has a temp limit option which would be way easier but it seems to be for nvidia only.
and i have tried both Bios switches.
R0H1T
2,583
164
Did you try any of these ~
https://www.techpowerup.com/vgabios/173026/powercolor-r9390-8192-150527
https://www.techpowerup.com/vgabios...ce=&memType=&memSize=&did=1002-67B1-148C-2358
The second link are unverified BIOS uploads, so be careful with them. If you need more info you could try TPU or ask here for further clarification.
atticus14
174
thanks for the link, I did try the normal one, but never came across the unverified ones. I'll try them out when I can.
