- Feb 23, 2007
- 538
- 0
- 0
(Cliffs at the end)
I've read through the recommendations thread again, but I'm still having issues trying to find a monitor that hits my ideal mark.
For reference, I have three NEC 20WMGX2 monitors plus a Dell SP2309W. There's also a 32" plasma attached to my system, but that's not a daily use thing. The Dell is my center main, one NEC above and to the left side landscape, and one NEC to the right in portrait.
The NEC is by far the best monitor I've ever used. But, I'd like to scale up from 20" as my main display. I purchased a 24" 1920x1200 HP LP2475w, but wound up cycling it out in favor of my current Dell SP2309W. The Dell has a 2048x1152 resolution @ 23", which gives it better pixels per inch/dot pitch than my HP. It looks more in-line with the NEC secondaries. The HP also had some color temp issues between left and right sides.
But, the Dell is a TN panel and needs a beating to get the colors I want (due to being a TN, though good blacks), has some backlight bleed and a crappy vertical viewing angle.
So what I'm looking for is a *glossy* IPS or VA panel. It has to have a low dot pitch (we're talking ~.25 or .26 mm at most). It must have at least two digital inputs (HDMI, DVI, DP), with multiple DVI inputs and/or a display port a plus. HDMI audio passthrough is also a big bonus. Size wise it has to be approximately 23" or larger.
Obviously, that's a pretty damn narrow subset of monitors. I'm not too concerned on price, but wouldn't like to go into the $1,000+ territory. I'm also staying away from 30" monitors due to physical sizes, price, plus I haven't seen any that are glossy. I dislike matte displays
The Apple 27" looks like a prospect if I forgo the connectivity options and break the bank.
After hitting up NewEgg for a while, I'm thinking I might be SOL, and stuck with either the TN Dell, or reverting to a cluster of the NEC's plus a DVI/HDMI switch box. If I get rid of the glossy requirement, that really expands the field, but I hate running a matte display in a cluster of glossy subdisplays.
Meh. I'm guessing in the end I'll have to give up my beloved NEC's if I want to go to higher resolutions/phsyical sizes and keep the dot pitch about the same. I suppose as a last ditch effort I could get another matte 1920x1200 24", use the 24" HP as a secondary, and retire the NEC's to alternates or something.
CLIFFS
-Want new monitor
-About the same pixels per inch as a 20"@1680x1050, or similar dot pitch to the NEC 20WMGX2 or SP2309W (~.25mm or less)
-Glossy
-IPS or VA (looking for quality)
-Minimum 2 digital inputs (some combination of HDMI, DVI, and/or DP)
-DP, multiple DVI, and HDMI audio passthrough a plus
-No 30"
*ALTERNATIVE: Glossy 24" IPS or VA @ 1920x1200 meeting all the above except dot pitch
CLIFFS
-Want new monitor
-Glossy
-No 30"
