I am going to purchase an Athloin 64 3200+ and build a new system. But have never built from scratch before. How good/bad are the stock CPU fans that come with the retail boxed sets? I am probably not going to overclock but want to keep my options open. So, I think that I want to get a better and more quiet solution. I am NOT going to ever overclock enough that I want to go all the way to a water-cooled system or anything else exotic enough to be featured in Maximum PC. 🙂
Lack of noise is extremely important. What would you recommend as an ultra-quiet high quality CPU fan (that will not totally break the bank--do not mind spending a reasonable amount but do not want to spend more on the fan than I do on the CPU itself)??
Do I also need something called thermal glue or tape?? How does that work and is it hard to install correctly for a first-timer?
