I'm looking for a small, compact case for a low power system. The system is going to be an Athlon II x4 with integrated graphics and one or maybe two hard drives. I am going to be using a Micro ATX board.
My last case lasted my around 8 years through 2-3 different builds so I am hoping for similar life out of my next case.
Right now I am only considering Antec...is there anyone else I should look into?
My short list right now so you can get an idea of what I am looking for.
Antec Mini P180 - I really like the way the case looks but it's not really much smaller than a normal mid tower. Also concerned about the proprietary 200mm fan at the top.
Antec Sonata Elite - Looks nice, worried that the side vent design next to the hard drives will be noisy
Antec NSK3480 - Much cheaper than the above two since it includes the power supply, but doesn't look as nice. Maybe it looks better in person? Also is the included power supply good quality? It has an 80mm fan on the PSU and I really wanted 120mm
Antec Solo - Seems to be a highly recommended case, but costs more than the Sonata...which is better? I am worried about the longevity of the rubber HDD mounts
That's pretty long for a short list. I'm thoroughly confused. Suggestions?
