Looking for a piece of audio hardware
I'm looking to try to run the audio jacks out of both of my computer's and into one speaker system. Back in my days of tinkering with audio hardware I remember a device that merged the output of two headset audio sources into one single speaker or headphone jack. Anyone know where I can find one of these? So basically I want computer A and computer B to share the same set of speakers. 🙂
Tried, but the only Y adapters I have found go from one source to two outputs.
I need an adapter that goes from 2 sources to 1 output.
you need to get the 2 male to 1 female y adapter...then get the adapter to make the male end fit your puter...easy as pie...mine is hooked up like that right now
Yeah, ask an employee if you can't find it- any electronics store should have them 🙂
