I've got an old thermalright slk-800 or 900 (can't remember, but they look nearly the same) and it's got quite a few small scratches/dents on the bottom from installing/uninstalling it several times over the past few years. It's original finish isn't really too smooth to begin with anyway.
Anyhow, I'm bored and want to see if I can get a better heat transfer by lapping. I've read this guide:
http://www.bigbruin.com/html/lapping-guide.htm
And have seen these products:
http://easypckits.com/products/
http://www.pcviper.net/index.htm
And was wondering what sort of kit I should to get me started (I can get my own glass).
I was first planning to get just a plain sandpaper kit from 400 grit to 2000 grit and just simply sand my heatsink. But is this a good idea? I see some kits include lapping compounds - are these just polishes or do they actually work like sandpaper? If they're just polish, won't they wear off under heat? Or if they're like sandpaper, are they better than 2000 grit?
Thanks for any information 🙂
