After looking at this thread, I am now, unfortunately more convinced that I am going to want a P-180 case for what I'm doing. A lot of you probably think it's going to be desecration as well, since it's pretty much the exact opposite of the intended purpose of this case.
I want to cut windows into it, and I want to water cool it...a lot.
My water cooling setup right now is a Swiftech MCP600 pump, a 5.25" bay reservoir, a 120mm Black Ice Xtreme radiator, and a 120mm fan (obviously).
The reasons I like this case are the 1) layout of the case (especially the PSU in the bottom), 2) tons of 120mm fan mounts, and 3) wonderfully smooth sides and top for unobstructed window cutting.
Before I say anything else I'm letting everyone know that I don't care about noise. The CPU and GPU will be watercooled. I'm only going to have like...2 or 3 120mm fans running in this case, and that will be plenty. Also, all of the 120MM fan mounts mean more options to put the radiator on.
The plan right now:
- reservoir up front in one of the 5.25" bays
- pump in the top set of 3.5" bays
* not totally sure what to do with the fan + radiator. It's going in one of the upper fan mounts by the top of the motherboard. I may end up cutting off most of the top and putting in a plexiglass window, and make my own custom fan mount up there.
This is sort of a feeler right now, as I am getting one of these cases for my g/f for her birthday and it comes in tomorrow. I wanted to get a few opinions though.
Also, if anyone has any ideas on what design I should put on my case, let me know. Right now one of the sides of my case has an autobots symbol cut into it, which is about a foot tall and a foot wide.
One last thing; if anyone can suggest another case with similar characteristics that would be better for what I'm doing, let me know. I've looked pretty hard at cases though, and I seem to like this one.
The plan right now:
