Looking for a good value modular PSU for a Micro ATX case.
balane
666
Things are pretty cramped in here so I'd like a modular or semi-modular power supply to keep extra cables at a minimum. This is going to go in a secondary computer for the garage and it will see some gaming (MMO's) and light productivity.
The hardware is; Q9650 OC'd, HD 5780 OC'd, 4GB RAM, SSD, 1 x HDD, DVD... I think that's about it.
Both overclocks are on the middle side, not a little and not a lot.
This is the Micro ATX case I have already and will be using.
http://www.coolermaster-usa.com/product.php?product_id=2721
So, good quality, ample power (Maybe a little extra for future upgrades if necessary.) and at least semi-modular.
I have no brand preference, I just don't want junk.
Thanks.
lehtv
11,897
74
X750 is around 200w overkill for his setup... His case isn't SLI friendly and the mobo probably doesn't support it anyway.
OP where are you buying from?
