Looking for a good quality paint to paint my case.
Adul
44
danny.tangtam.com
I know some people have used automotive paint for their cases, but I am not sure I want to go that far. I am looking to mod my case a little and give it a new coat of paint. Any suggestion, tips, tricks, etc would be appreciated.
Audiofight
2,891
Here's what I do to mod my own cases and have painted cases prior to sending them off to people when sold/traded here.
  • Lightly sand the surface with a fine grit paper (300 or higher at least)
    - helps paint to adhere
    Use a rag with rubbing alcohol (99% isopropyl is what I use)
    - removes paint dust and any oil from your skin, don't touch surface after this step
    Shake paint can and spray light coats (4-6 initially, 1-2 more after dry)
Paint - $.94 at Wal-Mart
Sand Paper - $2.xx for a couple sheets
Alcohol - $.84 at Wal-Mart
Less than $5 and you can start modding. The next case will only cost $1 b/c the sand paper and alcohol will be left over from before.
Audiofight
2,891
Dust wipes off with a cloth easily and if you want a high gloss shine.....use Gloss Black or any Gloss color to do it.
You can also buy clear coat in a can from the same places or in an arts and craft store. That will enhance the gloss.
All my systems have a mirror finish black paint job. At night, they seem to suck light into themselves. During the day, especially in sunlight, the look like a smoked mirror.
When painting them, you have to have a good area with very little to no traffic to stir up the dust. I paint things in my basement. Granted, not the best ventilated, but it is like a crypt. Dry and slightly cool, like 65F all the time. No humidity either.
Adul
44
danny.tangtam.com
damn I have a balcony to paint on :(
Audiofight
2,891
Not sure where you are located, but I am willing to do the painting for you. No charge other than shipping both ways...
Otherwise, you might want to find a different place to do this.....a balcony is going to blow too much stuff around...even on a calm evening. Never do painting outdoors.
Even if you have a friend with a garage. Throw some newspapers down and grab a windex bottle full of water and lightly spray the area to keep any dust/dirt away. The water will cause it to settle to the ground instead of floating....
Adul
44
danny.tangtam.com
thanks for the tips. I guess Iwill have to bug my friend over the weekend then :D
Audiofight
2,891
Spray the water up in air and left it settle to the ground. I didn't word that very well. The newspapers are for clean up afterwards of course (don't want paint on his garage floor :))
Good luck and let us know how it turns out
Adul
44
danny.tangtam.com
I will. I just got to find a weekend I am not busy doing stuff :x
LAN party next wekend... hmm
