LOOKING FOR A GOOD DUAL MONITOR VID CARD
wookieboy03
7
I'm looking for a good video card that can handle two monitors. I know that there are dvi cables that split into 2 vga adapters as well....so any card that can do that would work as well. I'm not sure what card to get, and i've been having problems finding information about some cards as to if they can handle the dual monitors if I were to hook up the 'Y' splitter. I don't have very much to spend unfortunately, probably $150 or less. thanks for any help.
Jan 31, 2002
40,819
The "Y" splitter days have long gone by, young Padawan. ;)
Everything but the most bargain-basement GhettoTech-brand cards will have two outputs onboard - usually one DVI and one VGA. A DVI-to-VGA convertor is included - and presto, dual monitors.
Far as card choices, what do you want to do with this dual-monitor setup? Game, CAD, 2D only?
- M4H
wookieboy03
7
hi, thanks for the info...
i mainly will be using them for photoshop, graphics, ect. a little bit of 3d here and there. primarily 2d though. any advice or suggestions on cards?
thanks
Soulkeeper
6,739
156
well just about anything can fit that role
how much money you looking to spend ?
