- Oct 21, 2006
- 5,401
- 2
- 0
I'm building a Christmas present for a friend that hasn't had anything but lower end Dells. On the inside it won't be anything special, a low end Core 2 Duo, 1-2GB of memory, 160-320 GB hard drive, some cheapish PCI-E card, etc. That will be more than enough to suit their needs.
However, they're ABSOLUTELY in love with all that glitters on custom PCs. I'm going to build a semi-modest case with a few glowy fans, and maybe a couple of UV Cathodes. I need a 90mm (or is it 92mm... or does the 2mm even really matter?) blue LED or UV fan that pushes semi-decent air without being wicked loud. I'm not expecting something that will outperform every Yate around, but they also won't appreciate a jet engine sitting on their desk.
Also, "smart" fans like the Thermaltake one I see so frequently are out of the question. I need something that I can plug right into a molex without having to worry about a fan controller to keep it quiet.
Thanks.
Thanks.
