Looking for a custom cable.. *FLAT* 30-Pin M to F
magnux
2,713
Has anyone ever come across a 30-pin M to F iPod Dock extension cable that is FLAT? I can find flat 30-pin M to USB all day -- but never an extension cable. I have a very narrow gap I need to fit the cable through, and a round one just won't fit..
DesiPower
15,299
740
Why do you want extension? why not replace the the cable, maybe with a longer one? You know Is the cable is too long it may not work...
OR why not use Flat, USB extension cable at the other end? they are a plenty...
bruceb
8,874
111
Check out the Digikey catalog. http://www.digikey.com
They have all sorts of cables and many types of connectors. Somewhere in there you should be able to find the type you require.
