Looking for a CMS (content management) Guide
SelArom
872
www.djselarom.com
hi, I'm looking to create my own content management system in asp.net 2.0, but I was wondering if there are any good references for things to consider when building one? I don't need any asp.net tutorials or anything like that, just an analysis of the requirements and things to consider when building a CMS so I can have something to refer to as I'm working.
thanks a bunch!
-SelArom
jjones
15,424
Don't really have any suggestions other than you might want to download Joomla and take a look at its structure. That will at least be somewhat helpful.
SelArom
872
www.djselarom.com
Originally posted by: GundamSonicZeroX
You can try Mambo. Personally I suggest learing HTML yourself. All my webpages have been coded from scratch.
heh fellas, I'm not looking for a CMS solution, I'm looking to build one myself. Looking at the structure of existing solutions is a good idea, but I'm looking for a more high-level overview of the CMS in general.
-SelArom
Atheus
7,313
He's talking about writing a CMS in ASP, I'm sure he knows HTML...
OP: I'm doing bits of one right now, it's not hugely difficult, but there's not many tutorials out there as every system is so different. For example our CMS has quite complex image editing/management parts, but a different site might just have an "add image to news item" button and leave it at that.
SelArom
872
www.djselarom.com
yeah I'm basically looking to make a site where people can add pages of content easily, maybe blogs, forums, etc, but REALLY simple. I'm just looking for a guide of what should be included and design issues (like storing in a database vs storing individual htm pages, etc).
-SelArom
Atheus
7,313
-SelArom
Well I'd definately go for a database - it's so much easier and more flexible. Have an entry for each page (obviously) and maybe keep a backup of each one so there can be an option to undo an edit. You have lots of user input and file uploads etc, so security is a major concern - check/validate everything to avoid injection attacks and malicious uploads.
SelArom
872
www.djselarom.com
yeah thanks, validation of user input is something I definitely want to consider, but I don't know much about that kind of stuff. does anyone know of any control in asp.net 2.0 that can filter out this kind of stuff? like scripts and html from textboxes? I'd like to enable the basic ones like em, a, strong, etc...
-SelArom
SelArom
872
www.djselarom.com
one of the things we covered in my software engineering class this past semester was developing a set of formal requirements, so that you have something to follow as you move forward in your development.
I would like to use this idea for implementing this system, as it is a pretty complex beast, and I want to keep things as organized as possible. What I would like to know then is this:
is there a formal mechanism (software, templates, etc) for itemizing these requirements? I know that I can use Use Cases and stuff like that, and I've got a little bit of practice with that, but I'm looking for something to keep track of the high level requirements and overview of the project. Should I just use a plain word file or is there a special way of storing this information?
thanks a bunch
-SelArom
tfinch2
22,114
Why reinvent the wheel? It's one thing to make a custom CMS to tailor to certain needs, but why waste time when a solution already exists?
SelArom
872
www.djselarom.com
1) because I don't like the solutions that are out there
2) because I want to learn
3) because I can :D
-SelArom
tfinch2
22,114
3) because I can :D
-SelArom
Are you already seasoned in ASP.net?
SelArom
872
www.djselarom.com
3) because I can :D
-SelArom
yep, I'm just looking for
a) a high-level guide of things to keep in mind when building a CMS
and
b) a way to formally document my progress
-SelArom
jjones
15,424
3) because I can :D
-SelArom
and
-SelArom
That's one of the reasons I suggest downloading something like Joomla. The code is well documented and you can see the logic in the way they built it.
cw42
4,227
Don't stop a man from wanting to learn.
I've been trying to make my own sort of CMS using PHP/MySQL. Not really all the successful so far because i'm having trouble with the PHP, but i'm learning. :)
