- Jun 30, 2004
- 16,587
- 2,000
- 126
Nobody told me I couldn't use laptop part technology in a PC, and I did -- for the first time four years ago, and with rave success as far as I'm concerned.
I'm using 2.5" Seagate spinners running at 5,400 rpm. For what I need in spinner performance, that's just fine. It makes my tower case lighter.
I also only had room for an ICY-DOCK 2x2.5"-hot-swap plus ODD device fitting a single 5.25" bay, and it also works great. At that time, I purchased an LG BU20N which I think is a Blu Ray reader and DVD/CD burner.
This time, I started looking for another, and now I figure I should have a BD-RE with Blu-Ray burning capability on top of the rest. I began looking around, and started feeling a bit panicky because most of the available units fitting my specification are off-name brands like "Valley-of-the-Sun" or "HAZYYO". I finally stumbled on an LG BU40N -- BD-RE-burner, handling DVD-R/RW, CDR/RW, etc. There are only about 14 customer reviews at Newegg, with a 4-egg average rating.
Amazon also has them, for $10+ dollars more -- one being offered for $18 more. They show 36 reviews with a 4-star average rating.
I can't keep up with the technology so well anymore. I think some people build desktops without ODDs in them, but I want an ODD in my computer just like I want a 12-CD-changer in my 26-year-old SUV, even though I've got about 500 albums available in the car from a USB source as well as an SDXC card in my Android tablet (which is mounted to the dash as semi-permanent).
When one has to look around a bit to find an LG laptop BD/DVD burner, one begins to worry. Other available units -- as I said -- are off-brand-names made in China. Which ones are good? Which ones aren't?
Anyway, I'll take a look at any recommendations forthcoming here before I pull the string on the BU40N.
