Lookin for some upgrade advice.
RedCross
183
I am thinking about upgrading my memory and possibly my CPU. Right now I have an Athlon XP 1600 o'ced to 1.8 ghz. My mem is True Samsung PC2700 256. If anyone has any suggestions, I am trying to go for most bang for the buck. Thanks in advance.
-Nate
Markfw
May 16, 2002
27,112
16,022
I vote XP2400 and another 256 meg of memory to match what you have.
DAPUNISHER
31,767
31,759
If you plan to keep the board awhile yet then the ram is fine just buy another stick 256mb or 512mb and a Barton 2500+ if your baord supports it.
RedCross
183
How overclockable is the Barton 2500??? And as far as RAM, I think you are right, I should just get another 512 stick of PC2700. Thanks for the help.
-Nate
