Lookin' for a decent portable gps
Thetech
571
I've read a little about them but I still don't know alot.
I'm looking for a good GPS that can just be mounted and removed in
my car easily (portable gps I guess).
As far as size goes as long as it's large enough to read, I don't
care about extra multimedia features, my main concern is that it says the
street names and is accurate.
TimeKeeper
4,927
In the U.S.
There are two major map provider, Navteq and TeleAtlas
Navteq arguely is much better in the U.S. ( many review sites proven to be more effective)
Navteq equipped GPS are: Garmin, Magellan, Navigon and etc.
TeleAtlas GPS are: TomTom, MIO, Harman Kardon and most of "after market" GPS.
Now, GPS chip. (bare in mind same chip may perform differently due to design and model)
There are
Sirf (it is 3 years old and not exactly better than other chip nowadays)
Bravo ( mainly seen on Nuvi 200/250, has know issue of slow satallite acquisition)
MTK ( use on Nuvi 260 and will implement into 2x5 series, it has one of the fastest and most accurate positioning I have tested)
Hammerhead ( known to be in TomTom, it clearly show its advantage over Sirf in accuracy)
Centrality Atlas/Titan ( known to used w/ Multimedia GPS, it has good accuracy, but tends to drain out battery rather fast, such as Harman Kardon, iPaq , New Magellan 1xxx series)
Size: 3.5" is easier to remove and hide away.
TTS: it is usually quite useful if you are in a major city where many streets joint together. Or on the highway w/ Multi-exit, it will tell you to get off Exit 12"A" or Exit 12"B" instead just tell you get off in .2 miles.
Safty: all gps come w/ windshield mount, but I strongly suggest buy a Vent mount, or something not shouting out.... "hey, I got a gps in my car, come and break my window"
Portability: Battery life. ... most of Slim auto GPS wouldn't last more than 2 hours per charge, currently Garmin Nuvi 2xx series top out w/ more than 4.5 hours real life.
Tomtom will not last more than 100 min.
POI: thankfully, most of GPS unit come at least 6 million poi.
Via point: do you need to plan trip w/ more than 2 stops? Tomtom / MIO / Magellan tends to have better function w/ via point. For pure simplicity, Garmin is the choice.
Routing engine: Again, Navteq equipped GPS in the U.S. tends to perform more accurate routing.
Bluetooth: well... I don't know about talking to the GPS. Most cars nowadays already come w/ BT connection.
TMC: traffic message channel, on "high end" model, and usually can be quite useful for those heavy traveler. (annual subscription usually apply)
With all those GPS I have tested including entire Nuvi 2xx line up, 3xx line, 6xx line, TomTom one/2/3, TT7xx series, Magellan 32xx/42xx, Mio 3/5/7, Harman Kardon 3xx/5xx and more.. I kept a Nuvi 260 MTK-chip.
p.s. I never test Navigon gps, hence, I can't tell you how it perform
TimeKeeper
4,927
BTW, if you are interested in any particular GPS's UI. (model that I have tested)
Let me know, I have real life comparison photos that I can show you.
Including their battery size and board...( yes, I dissect every GPS I tested on) :)
Thetech
571
In the U.S.
There are
Holy Sh*t! :shocked:
Tons of juicy bits, I'll have to figure out some specific models before I can get a reference from you, but this is AWESOME!
I drive an '08 Honda Civic (LX I think, just 1 step above the lowest Civic) As far as I know it doesn't have bluetooth.
Thetech
571
Sweeeet, what do you think of this one, Timekeeper?
It has route optimizer, quick fix, bit short of 3 hours battery (with BT on) which make it a great gps.
But since GPS price is dropping and I don't use it everyday, I am too cheap to spend more than $200 for any TTS GPS anymore. :)
Is there an alternative you'd recommend? I think the bluetooth feature is cool, but not needed,
I don't have a use for any multimedia features, I have a digital music player that I hook up to my cars line in, so mp3 playing is not needed either.
nageov3t
42,808
83
not to hijack. but anyone have any thoughts on the easiest to use GPS for someone who totally hates technology and is reluctant to learn anything new?
my dad is totally in need of a GPS unit... he gets lost inside paper bags, but he looks with anger and suspicion on any piece of electronics equipment produced after the 60's.
TimeKeeper
4,927
I would think Garmin has the easiest UI. ( entry level model, and my wife never ask me "how do I.......... " )
2 choices on main menu.
one button quick location save.
one button cancel route.
one button reroute.
Thetech
571
No problem, someone should be able to take something away from this thread, I can't afford the first model I mentioned, maybe the 255 will be alot cheaper, how about 50 dollars? lol.
CowZ
188
I use the Tomtom One 3rd edition. I like it although sometimes its kind of quirky.
Thetech
571
How about the Garmin StreetPilot c330, Timekeeper?
I read a review at cnet and it seemed ok. I thought maybe I could buy this one and then upgrade next year or whatever.
TimeKeeper
4,927
C330 using 2nd Gen UI. (little not so refined graphic)
Also it has been officially discontnued.
C330's LCD screen is really not "acceptable" in today's standard. It tends to washout completely in the sunny day. ( NOT even directly )
Currently I don't have C330 screen shot, but below is
Nuvi 2xx series vs TomTom. (that will show you the display quality in real life)
Nuvi 2xx vs aging Nuvi 3xx ( and most people already think Nuvi 3xx has good display, well....think again)
http://home.comcast.net/~passion4gps/nuvi350/3vs2.jpg
http://home.comcast.net/~passion4gps/nuvi350/3vs22.jpg
http://home.comcast.net/~passion4gps/sale.JPG
If you plan to upgrade later, might as well shop for used Nuvi 200 from your local Craigslist.
Thetech
571
Wow, I didn't think that the 3xx series would look worse. Thx.
TimeKeeper
4,927
I think I mentioned somewhere before, that I wouldn't buy any aging Nuvi 3xx series.
Plus, look at the fist pic I provided again.
Street info is not adequately provided. "NW" in front of the street number is totally different area compare to "NW" place behind the street name.
Thetech
571
Hey Timekeeper,
I can't really afford to even spend the $300 on the 760 :frown:
What's your take on the 260, and would it make a big difference that it's not widescreen?
like I said, bluetooth is a plus, but I don't need a picture viewer or a music player, that's what I have a Digital music player for.
TimeKeeper
4,927
I said w/ all those gps I tested, I kept a Nuvi 260. :)
here is my little comparison between 4.3" vs 3.5"
http://www.gpsreview.net/forums/viewtopic.php?t=4138
And it is really not about you able to afford it or not, I really don't think average people need to spend more than $200 for a gps nowadays.
Thetech
571
Now I'll just have to see if Best Buy will let me use this coupon coupon
2 more questions, do you see the price of this falling soon?
And would you recommend that I get the 2 year extended warranty.
TimeKeeper
4,927
I can't tell you about warranty part. ( but I haven't bought any warranty on item less than $1000 before )
Garmin is introducing new 2x5 line (also equipped w/ MTK), so I believed Nuvi 260 should drop also. Nuvi 200 priced drop the most. But Nuvi 260 haven't drop much since last black friday.
nageov3t
42,808
83
got my garmin nuvi 760 in the mail earlier this week and I :heart: it.
I'm notorious for my capacity to get lost anywhere at any time... tonight, I drove around for an hour and a half in central/south NJ farmland, making totally random turns in towns I've never been in before.
after an hour and a half, I pulled my garmin out of the glove box, hit the "go home" button and it took me home with nary an incident. that's all I can ask for, really. :)
