Logitech Z640- no rear sound on NForce 2
Dudd
2,865
I'm not exactly sure what the problem is here. I've got a mini Shuttle with the NForce 2 motherboard, and for some reason, the rear sound doesn't work. I have it set up for six speaker mode in the NForce control panel, but that doesn't do anything. If I leave Dolby surround off, only the left and right make noise. If I check it, then the left-center-right-left surround-etc all play, but only out of the left and right speakers. Any clue as to what I'm doing wrong here? I just checked, and everything is plugged in correctly.
JBT
12,094
NForcersHQ check this site out and visit thier audio forums they should be able to help you it seems to be a common problem with the latest drivers but its fixable.
daddyo
Download NVSWAP from the same site listed above. It's a utility that will help you setup your speaker outputs.
