Hi all,
I heard a humongous amount of praise for the Logitech-Z5500 D and so I got one for myself. According to some users, it shakes the wall and windows at half the volume. Well, in my case that is not happening. I have connected the speakers to the PC using the analog cable that came with the PC. My soundcard is the Audigy2 ZS Platinum PRO and I have checked the speaker settings. However, it is only after I turn up the volume to about 3/4th of the total bars shown on the control hub does the volume actually sound higher. But sorry, no shaking walls or windows. The Master volume and the Wave volume of the sound card is set to 70% while the volume controls in Winamp and WMP 10 are maxed out. The same amount of volume on my previous Altec Lansing 641's would make me reach for ear plugs. EAX and Equalizers on the sound card is turned off and so is CMSS.
Another thing that I noticed while calibrating the the speakers using the Creative Speaker calibrating software was that the satellites were getting properly calibrated but when it came to sub, there was a strange repeated "bing,bing" sound that emanated from all the satellites and the sub. So I just by passed the test and went ahead. Do any of u think there is something fishy and I got a lemon from Logitech??
Steam.
Steam.
