I just bought this logitech wireless mouse (silver with dark blue trims) earlier this week. The mouse can work with either ps/2 or USB connection. I used the PS/2 as it is the recommended connection for desktop pc according to logitech's user manual. The mouse works great but it has this nagging connection problem. I must press the connect buttons (one on the RF receiver and another underneath the mouse) during each cold boot in order to establish the radio signal connection between the mouse and the receiver. Otherwise, the mouse will not function at all once the computer boots into Windows XP SP2. Having to press two more buttons during each cold boot is quite annoying.
I am just wondering is this normal for wirelss mouse or is it because I am using the PS/2 instead of the USB connection?
