Logitech Wireless Mouse M510, M515 or M705?
King Mustard
164
I'm looking into getting a wireless mouse for my PC.
I have settled on Logitech because I am also going to be buying a Logitech K360 wireless keyboard, and I like the idea of both pieces of hardware using Logitech's Unifying receiver.
I want a full-size Logitech wireless mouse but don't want to spend more than £35.
I believe my options are: Logitech Wireless Mouse M510 (2010), M515 (2011) or M705 (2010).
Here is a comparison of the three from Logitech's website.
I do play games on my PC, but I couldn't tell the difference between my £50 wired lazer G5 and my £35 wired optical MX518, so I don't mind whether the wireless mouse is optical or lazer.
Anything I should consider? Any advice?
TY-1
186
I use an M510 with my desktop at work and it is very comfortable. I don't think in the nearly three years that I have been using it that I have had a single problem with it. It is very smooth and responsive. The buttons are neither terribly stiff or loose but respond well. Battery life, I find, is great as I have only had to replace the two AA batteries twice now and I leave the M510 on 24hours a day 7 days a week. It wakes pretty quickly from sleep with little lag.
