Logitech Wheel Mouse Optical
Bengt4
68
Hi there, I just wanna know if this mouse don't BUG when you do fast movements, like the old Opticals. That's IT... =]
It's good for games like Quake 3 and CS?
Bye bye!
Mem
21,476
13
I`m using a Logitech Optical Mouseman Wheel (the blue model which has been discontinued)and works ok for me with those games,I`m using an Everglide Giaganta mouse pad which helps a lot,I would suggest for the best gaming experience to get a logitech Dual Optical or Microsoft Intellimouse Explorer 3 ,these are the best mice for gaming & if you team them up with a Ratpad or Everglide Giganta you will have an awesome mouse gaming setup.
RudeBoie
2,017
If it's a 2x optical, you'll be fine. If it's an original one, my friend has one of those, and I sense a bit change from my Ifeel to his.
teddymines
940
I have the 1x logitech optical, and it sometimes does tweek when I do fast movements in UT. I'll scream, "No! I do NOT want to stare at the ceiling and spin around while being perforated!"
DAPUNISHER
31,701
31,573
LMAO :D I like the logitech myself and hear too many complaints of short life spans on the MS opticals. EDIT:lifespan of the mouse NOT your FPS character ;)
jrichrds
Just to clarify...
2x Optical - optical sensor has twice the resolution of Logitech's previous optical sensor.
Dual Optical - Logitech mouse with two optical sensors, both of the 2x variety.
