Logitech quickcam web problem using with XP and VIA chipset
kkdon
Hi:
I have a logitech quickcam web http://www.gearpreview.com/tech/webcam/qweb.html
However, i have problem when i use it under XP and my ASUS A7V (via chipset). For some reason it works fine on all other PCs running XP, and it also runs fine on the ASUS A7V board under Win 98.
But if i run XP on the ASUS board, the quick cam web will get detected..and it will run and capture images as usual but very quickly it'll freeze. I can still use other programs but whatever program using the camera will freeze and I have to kill it.
Tried installing those VIA 4-in-1 pack and USB filter stuff. Nothing really helped. Anybody knows of a remedy? I've read many forums and a lot of ppl seem to have having this problem as well. They claim it to be a problem with Xp and the via chipset. sort of like a "perfect storm" problem.
Let me know if anybody has a solution to this. Help appreciated.
please email me at donaldleung@rogers.com
Don
There is nothing you can do for this setup. I ran into the exact same problem on a VIA board. There is a problem that via lists right on their website for an incompatability with the VIA USB southbridge and USB logitech cameras. I tried everything you can imagine, but finally I had to change the mobo to an intel based solution.
Very annoying. Just shows the inferiority if VIA chipsets. I will never buy another VIA based board. There are plenty of other solutions out there that work just fine and who take the time to ensure compatability with most devices.
Keys
I know you cant use Intel solution, just noticed that you use AMD. Nforce2 board should work beautifully, or SIS.
