cam
DESCRIPTION
VGA sensor with RightLight technology. Superior video performance in low light situations. Built-in Microphone with RightSound technology. Cancels echoes so you can make video calls without wearing a headset.
FEATURES
Standard Warranty 2 Year(s) Limited
Interfaces/Ports USB
Lens Type Fixed focus lens
Manufacturer Logitech
Total Resolution 1.3 Megapixels
Manufacturer Part Number 961419-0403
Product Name QuickCam Pro 5000 Webcam
Product Type Webcam
EXTENDED SPECS
Package Contents QuickCam Pro 5000 Webcam with built-in mic6ft USB cableAdjustable baseQuickCam Software CDCamera set-up guideAudio set-up guideStereo headset
Focus Mode Fixed Focus
System Requirement Windows 2000, XPPentium P4 1.4 GHz or AMD Athlon processor 1 GHz (Pentium P4 2.4 GHz or better recommended) 128MB RAM (256MB RAM recommended)200MB free hard drive spaceCD-ROM drive16-bit color display adapterWindows compatible sound card and speakers (full duplex sound card recommended)Available 1.1 or 2.0 USB port (USB 2.0 High Speed port required for megapixel image capture)
Product Line QuickCam
Video Resolution 640 x 480
Platform Support PC
Product Type Webcam
not a bad price for those looking to buy this cam it retails for $79.99
DESCRIPTION
FEATURES
Product Type Webcam
EXTENDED SPECS
Platform Support PC
Product Type Webcam
