Logitech optical USB mouse and WindowsME ?!?!?!?!
CyberMenace
35
Hi peeps !
7 out of 10 times I restart or just power up my system, my mouse doesnt get activated !!! after another reboot or today I even had to reboot twice, it gets activated.
Sometimes windows just starts up, but sometimes I also get that blue screen. With the following errors(1 line per error screen that is):
OB : 0167 : 000075DS
OE : 0167 : 00006655
O6 : D14B : 0000FF34
OE : 0187 : BFF62808
Any ideas if this is my mouse or is it windows ???
thanks in advance.
PS I'm also posting this in the Operating Systems forum.....
pyr
did you install the software? if so what version. if not, try that.
bogdan
17
I read somewhere that Windows Me does not like logitech mice.
It is a driver issue Logitech apparently could not care less.
I was using one and getting all sorts of weirds things happening.
I uninstalled the logitech drivers and just used the Win Me ones and it has been fine.
However that was with a normal logitech USB mouse.
I am assuming you use the same drivers for both.
Anyhow i am going to get one tomorrow I will let you know if I have a problem using Win Me drivers with it.
bogdan
nightowl
1,935
Are you using USB to connect the mouse? If so, I was having the same problem with the same mouse only on Win2k. It would do the same thing you mentioned, Windows would not initialize the mouse. Also, whenever I would print the mouse would die at random. How did I fix it, by using the PS/2 adapter.
