Logitech optical not working propertly with counterstrike?
Everytime I play counterstrike and turn left or right fast, I don't seem to turn. I think the optical mouse is not the problem. As other optical mousing don't do this behaviour. My other friend with the logitech optical has the same problem. What should I do? Works fine in regular stuff.
Hmmm mine works fine, have you tried adjusting sensitivity for CS under options in customize then advanced and have you tried turning up the acceleration to high in control panel, also are you using latest drivers?
Also I find the surface the optical mouse is on does matter for speed etc so try a different mousepad or if you are using the desk try something under it.
