Logitech Mx700 and KVM Problems
Ausm
14
Does anyone here use a logitech Mx700 in conjunction with a KVM switch? I am currently running an Omniview PS2 4 port KVM and I can't get my new mouse to work on it at all!! :( When I plug the mouse into an USB hub or the PS2 port on my computer it works great.
If anyone has found a fix LMK and also what hardware you are using also.
TIA
Ausm
chizow
9,537
I remember reading a similar problem with the MX700 some time ago with certain KVMs. Apparently some KVMs have an issue with supplying the necessary power/signal to the MX700's base. At least one person was able to get their MX700 to work with a KVM. Try an advanced search in peripherals or hot deals (as far back as you can go) and search for KVM or dig through one of the larger MX700 threads. I'm almost 100% positive it was in one of those two forums.
Chiz
