I am using a Linxcel 2 port switch with my MX duo. Every once in a while switching will cause the mouse to lock up and require a reboot. This happens about 1 of 10 "switches" and will most of the time happen the first time I switch it on a fresh boot.
I just use it to easily access my webserver, so maybe once a week at most. Works for me. I don't use the monitor function as my LCD has DVI and analog.
