Logitech Mouseman Cordless Optical problem
thegreenberet
100
Hi, I have the mouse mentioned in the title of this thread. I've had it for about a month, but now it starts acting weird. It constantly turns itself off, so that i have to push that little connect button located under the mouse. Is that a typical sign of the batteries starting to get bad or...? Think it's weird though. Arent the batteries supposed to last for bout 2-3 months ?
Thx in advance.
Jun 22, 2001
79
The average life of the batteries in your mouse is suppose to be 2-3 months. But that depends - If you place your mouse far away from the receiver, it will more use signals, therefore using more battery life.
But, if it is your battery, it should warn you.
Try updating the firmware-I dont know if'd help.
Did you try changing batteries? If you didn't, TRY
diesel_incorporated@hotmail.comnull
