Logitech keyboard's hotkey's won't work.
porschetr
74
I have Logitech MX3000 wireless keyboard.
Yesterday I installed it to my new computer and all the hot keys won't work.
-yes, the SetPoint icon is at the bottom task bar.
-connected with USB
-Linked properly
Any idea why? Not compatible with new hardwares?
bruceb
8,874
111
You need to go into Setpoint and make sure that it sees the correct device.
If not select it. It will show an image of what you have. You can then select
whatever key or button you want to customize
