Logitech G7 batteries?
gryfon19
26
I'm interested in the G7 mouse, but I see that it comes with 2 Li-On batteries. Can those be recharged, and if so, then how? Thanks for ingsight...I, of course, don't want to buy a mouse that I have to constantly replace the battery. Thanks.
eelw
10,352
5,501
One gets recharged in the mouse itself when on the charging bay. The other connects directly to the charging bay. This way, it the one you're using dies, you can quickly swap with the fresh one on the charging bay.
FlasHBurN
1,349
Uh, what? There is no place on the 'charging bay' to put the mouse. You put one of the li-on batteries in the mouse, and the other one goes in the charger. You swap them when the one in the mouse gets low.
tuteja1986
3,676
Logitech MX1000 battery lasted me a week without recharge at all :) they are still working and logitech 7 batter take it to another level
Grimner
176
So you just slap a new mag in your mouse? :)
Sweet. Good of Logitech to finally make a sensible solution for cordless mice. Now if they could do the same for cordless mice targeted for office use. In tech support there is endless fun with dying mice batteries...
clickynext
2,583
If you use them a whole lot, each one only lasts about a day, but you'll never run out with two of them. Plus, you can put the charger on a "boost mode" and it only takes something like two hours to charge.
Tennoh
So has anyone found where to buy replacement li-on batteries? Something with maybe higher mAh than the standard G7 li-on.
